gauge parameters
Nusmi
gauge parameters
Post by Nusmi »
Hi guy's,
I have a MAP sensor 0-4 bar, why can't I set a gauge between -1000 and 2500 mbar? No matter what input I use, it refuses...
Why ? how can I do? (Intake pressure manifold or boost pressure) I don't know, I don't understand.
Re: gauge parameters
Are you referring to an analog input on the s300?
Nusmi
Post by Nusmi »
No, I said the map sensor 0-4 bar Hondata , So why can't I make an intake pressure gauge set between 0 and 4 bars?
Input intake manifold pressure or boost or Or anything that gives me the manifold pressure..
I'm sorry, but I'm not understanding what exactly it is you are trying to do or what Hondata system you are using.
Nusmi
Post by Nusmi »
What don't you understand? I have a Hondata S300, I have an engine, I have a Hondata 0-4 bar sensor (since it's a turbo setup), and I want to set the gauge to -1000/2300 mbar, but the Hondata dashboard rejects it with an "invalid input" error and resets the gauge to "factory".
