gauge parameters
Posted: Fri May 22, 2026 9:26 am
by Nusmi
Hi guy's,
I have a MAP sensor 0-4 bar, why can't I set a gauge between -1000 and 2500 mbar? No matter what input I use, it refuses...
Why ? how can I do? (Intake pressure manifold or boost pressure) I don't know, I don't understand.
Re: gauge parameters
Posted: Fri May 22, 2026 10:13 am
Are you referring to an analog input on the s300?
Posted: Fri May 22, 2026 1:10 pm
by Nusmi
No, I said the map sensor 0-4 bar Hondata , So why can't I make an intake pressure gauge set between 0 and 4 bars?
Input intake manifold pressure or boost or Or anything that gives me the manifold pressure..
Posted: Fri May 22, 2026 2:25 pm
I'm sorry, but I'm not understanding what exactly it is you are trying to do or what Hondata system you are using.
Posted: Sat May 23, 2026 11:11 am
by Nusmi
What don't you understand? I have a Hondata S300, I have an engine, I have a Hondata 0-4 bar sensor (since it's a turbo setup), and I want to set the gauge to -1000/2300 mbar, but the Hondata dashboard rejects it with an "invalid input" error and resets the gauge to "factory".
