Knock around 2800-3500 rpm Honda Civic FN2
tmgt
Post by tmgt »
Honda Civic FN2 Type R (K20Z4) with Hondata FlashPro.
Current setup:
TSS intake
Custom sealed airbox with cold air feed from the fog light area
4-2-1 header
200 cell cat
2.5" exhaust
Shell V-Power only
I'm experiencing knock events in the low cam area around 2800-3500 rpm while driving uphill in 6th gear at approximately 750-850 mbar MAP. The issue is repeatable and mainly occurs under sustained load in higher gears.
What is confusing me:
* IAT is only around 25°C
* AFR tracks the target very closely (around 12.9 AFR in the affected area)
* Ignition timing is already significantly lower than stock in this region
* VTC advance has also been reduced compared to stock
* Knock retard is usually only 1-2°, but Knock Control increases significantly
* The knock counts are almost exclusively on cylinders 2 and 3
* I cannot reproduce the issue in 3rd gear under similar RPM and MAP conditions
I have attached the calibration and datalog. Based on the logs, does this look like genuine combustion knock, cylinder-to-cylinder fueling imbalance, VTC related, or possibly false knock/resonance from the exhaust/intake setup?
Any feedback would be appreciated.
Re: Knock around 2800-3500 rpm Honda Civic FN2
Try reducing timing in that area and see if the knock goes away.
tmgt
Post by tmgt »
Spunkster wrote: Wed Jun 10, 2026 11:31 am Try reducing timing in that area and see if the knock goes away.
Thank you for the fast response. I‘ve already reduced the timing for 2-4 degree. The Knock doesent go away.
CalibratEd
Post by CalibratEd »
tmgt wrote: Wed Jun 10, 2026 11:38 am
It maybe false knock. It’s possible you have something loose or a rattle.
-Ed
Instagram: calibrated.tuning
