Need help with the basemap & datalog
Hoodiephilly
Post by Hoodiephilly »
K24a2 swapped 5 speed Acura csx with si ecu & flahpro
I have my basemap file and one datalog file, very new to all this. If anyone could help and take a look at it maybe make a revision that would be amazing.
Hoodiephilly
Re: Need help with the basemap & datalog
Here’s the calibration I’m running & the datalog I recorded.
Hoodiephilly
Car info
04-06 K24a2 rbb3 full long block
25 degree vtc, 2.5 inch sri
Stock header & exhaust currently
Type s oil pump
Rbc, 310 cc currently
Factory 5 speed csx trans
Civic si ecu & wiring
Car was originally a auto base model
Acura csx but has been converted
Any other info needed I can provide.
Hoodiephilly
Can someone please help
CalibratEd
Post by CalibratEd »
The car is running lean. You are maxing out the STFT trims. I added fuel to all of the tables to bring the trims down.
-Ed
Instagram: calibrated.tuning
