CVT Temp
Re: CVT Temp
I saw on the forum that it works fine in version 4.4.7, but it's broken in 4.7.2. Is this a known bug in the latest release ?
viewtopic.php?p=141096&hilit=CVT+TEMP#p141096
Re: CVT Temp
retry in my flashpro 4.7.2 still not work , could you help to carify it . thanks~
Re: CVT Temp
Is it possible to support this feature?
Re: CVT Temp
Sorry, it was fixed in 4.7.3 early July and should be working in 4.7.3 and subsequent releases.
Re: CVT Temp
Thanks Hondata. After updating to v4.7.6, I am now able to monitor the CVT temperature successfully!Hondata wrote: Mon Aug 03, 2026 9:46 am Sorry, it was fixed in 4.7.3 early July and should be working in 4.7.3 and subsequent releases.
Re: CVT Temp
After testing for a few days, I found the issue. The values monitored on the mobile app appear normal, but when I load the datalog from the FlashPro unit to my PC, the CVT temp always shows 0
Re: CVT Temp
Were these datalogs made with older software?
Re: CVT Temp
software version is 4.7.6
and also can't see the Torque in log
Re: CVT Temp
after update software to version is 4.7.7 sill can't see CVT Temp and Torque in log ....
Re: CVT Temp
are these new datalogs made with the new software or old datalogs?
Re: CVT Temp
old log w/new sofftware-->can't see CVT Temp and TorqueSpunkster wrote: Fri Sep 18, 2026 12:01 pm are these new datalogs made with the new software or old datalogs?
new log w/new software --->can see CVT temp , can't see Torque
Re: CVT Temp
update:
After reviewing the new log with the new software (v4.7.7), the CVT temperature value appears unstable and randomly drops out/fails to display.
