FK2 Calibrations - Comments and Instructions Need
tak.wai1216
Post by tak.wai1216 »
I have used the available calibration for FK2, just ticked the boxes for increased boost limit. I have datalogged few times, and transferred to PC and check is the car running ok.
By using some comments found in the forum, I have noticed the short trim % is between +11 and -10, not within +5 and -5 range, so how to adjust to optimal range? The long trim% is between +4 and -3. I have also found there os a knock % of 4, is that mean a problem there?
Re: FK2 Calibrations - Comments and Instructions Need
If you have an aftermarket intake then the AFM may need to be fine tuned to get the AF correct.
