Alternate VSS input issue
I have entered the correct gearing for this car (BMW). It will display the speed from the alternate speed input but launch control will not disengages and I have no VTEC
Re: Alternate VSS input issue
How do you have the VSS Signal connected to the ECU?
56962 purchased from Humble Performance
I'm sending the signal through a Dakota Digital SGI-100BT
But how is it connected to the ECU?
Into the alternate VSS input
There is no reading of the VSS in the datalog you have posted.
It shows up under vss input for me
The datalog you have posted does not show any VSS activity. Datalog again and post the datalog and the calibration it was made with.
That's picture is from the datalog I posted. It says 0mph on vss but it shows up under vss input just like in the picture.
If there is no vss showing in the actual datalog and you are having issues with the VTEC and launch control, then the ECU is not seeing the vss signal.
Why is it showing up under vss input then?
It's not in the datalog you have posted.
Can you explain what this is?
Sorry, I tried to attach a picture. Can you explain why I can see a VSS input like in the picture I posted. The MPH is even correct
I cannot, as you are not getting a vss signal in the actual datalog, so the ECU cannot see this signal.
