2012 hondata base map high knock count !!
So I’m new to this. Recently got this 2012 si coupe. Did the short ktuner intake and skunk down pipe with greddy exhaust. Got a hondata and did the base short ram intake and ... exhaust map but I’ve been seeing a high knock counts and knock control. My question is. Is this normal or do I need to have some to take a look at the tune. Bc my understanding was that the hondata tunes were generally safe to run of the box 🤷♂️
Re: 2012 hondata base map high knock count !!
If you are getting high knock, then you should have someone look at it and try to custom tune it so that you do not get that.
