Main Cruise Button & Effects
yaggs89
Post by yaggs89 »
Currently using FlashPro for '20 civic Si...
It is well documented in the help file that "enabling the main cruise control button will cause the throttle to go back to stock behavior". This is stated specifically for Rev Hang and Traction Control.
I have observed that in addition to Rev Hang and Traction Control, it seems to me that the following parameters are affected:
- Throttle sensitivity and Response settings (obviously)
- Optimized Turbo Response
Also, there is sill a change in throttle behavior with main cruise on and off, even with "Standard" sensitivity/response selected in the parameters. Seems it's not exactly "standard" if it changes with main cruise enabled.
My question is: Specifically, what parameters are reverted to stock with main cruise button on?
Thanks in advance
