I was thinking and -
amctmg
Post by amctmg »
would it be possible on one of the future updates to add a feature that you could simply click a button to adjust the fuel table to what is suggested after a datalog instead of having to go through and do it manually.
also, is it possible to have a feature that could calculate your mpg instant and average?
I've been doing dozens of datlogs and making the suggested fuel adjustments but it seems the next data log after the next all need major adjustments. I've made the adjustments leaving it on all tables and it seemed I still wasn't getting anywhere and I tried looking at the cam angle ang adjusting the fuel for that single table and still keep needing adjustments anywhere from -1 to -27. I finally started doubling the suggested adjustments using all tables and after a few datalog with this method I've gotten it alot better but still not quite the 13 to 13.5 range thats desired. it still seems to dip down to the mid 12's at times.
here is a log and the kal I've been messing with, let me know what you think
BTW this kal has had a little timing advance added since I was getting comfortable with the fuel.
Are there any cam angle adjustment you would suggest or must I purchase dyno time to mess with cam angles?
thank you
edit: on this log you can se 1st through 3rd are fine af wise but 4th gets very rich and if you look at the afcmd in sensors you can see that it is in the low 11's at times WTF :(
02 civic si IHE Kpro 550cc w/nitrous
amctmg
Post by amctmg »
Ok I tried something else, I loaded up the civic si greddy 550cc kal and datalogged and adjust the fuel a little and then did this run. The af is fine till I hit 100 and then it drops like a rock.
could I possibly need to update the firmware?
What ECU are you using, and what gearing do you have?
amctmg
Post by amctmg »
Hondata wrote:What ECU are you using, and what gearing do you have?
I just got kpro a month ago for a 2002 us civic si with a stock ecu SN# 783 and I'm running the latest 1.1.9.0
the transmission has not been touched so whatever stock is
Update: I've found a problem in the Civic Si program where it will go rich under some circumstances, and will fix this in the next release (May).
amctmg
Post by amctmg »
Hondata wrote:Update: I've found a problem in the Civic Si program where it will go rich under some circumstances, and will fix this in the next release (May).
I will wait patiently, kinda seems weird that noone else has complained of this issue, atleast that I've seen.
thank you
