FlashProManager 4.7.6
Posted: Mon Aug 10, 2026 10:04 am
FlashProManager 4.7.6 (7 Aug 2026)
- [FL5/DE5] Fixed radiator fan temperature settings
- [FL5] Fixed pops and bangs for 2026 models
Download
here
Please only post in this thread if directly related to the software release. It is not the place to request features.
Re: FlashProManager 4.7.6
Posted: Thu Aug 13, 2026 1:38 pm
by FK8_Hoonigan
May want to check the Compare feature on v4.7.6, with multiple tables and fields changes, most of list is NULL.
Tested previous versions, compare feature its working fine on those.
Posted: Thu Aug 13, 2026 4:02 pm
Please post the calibrations you are trying to compare.
Posted: Fri Aug 14, 2026 8:55 pm
by jeffx
I checked it myself with just using a baseline calibration and then altering it (these files are attached). The compare function in 4.7.6 shows no differences at all. (no screenshot attached, because it's literally an empty table of output on 4.7.6)
On an earlier version of FPM, it shows this (which is correct)
Posted: Sun Aug 16, 2026 4:58 pm
by mike_99gsx
I can not get my Flashpro to update its firmware with 4.7.6 I have tried uninstalling the software and reinstalling. Normally the prompt immediately comes up for me to disconnect the OBD2 harness and do it but nothing will pop up. Flashpro is currently on 4.7.5
SN: FP-ITS-420522
Posted: Mon Aug 17, 2026 9:45 am
mike_99gsx wrote: Sun Aug 16, 2026 4:58 pm
SN: FP-ITS-420522
The firmware was not updated in this version.
Posted: Mon Aug 17, 2026 3:27 pm
Our software engineer is looking into the compare issue.
Posted: Fri Sep 04, 2026 7:18 am
by Fkay8
Are there any updates regarding the status of this issue?
Posted: Fri Sep 11, 2026 5:26 pm
by dmoraroj
jeffx wrote: Fri Aug 14, 2026 8:55 pm
I have this same issue with this version. "Compare" option is not working anymore.
Posted: Fri Sep 11, 2026 5:58 pm
Please email
support@hondata.com the two calibrations you are comparing. If you can, include a link to this thread.
Posted: Mon Sep 14, 2026 11:50 am
It should be fixed in the next release
