Need Help , Engine will not start
Turbomo
Post by Turbomo »
Hello
I have a Crx 1991 DOHC V-TEC 150PS with Turbo and Hondata P28 with S200 (Boost,Datalogg.), 440ccm Peak and Hold Injectors, OBD0 to OBD1 Conversion Harness.
The following problem:
I would start the first time (after the turbo change).does not start however.
1.gasoline pump does not start(is however not so bad, Relay bridges)
2.The red Led in the S200 blink (on,out,on,out......)
3.The injectors have permanently Ground and Power (They hum completely quietly) even with taken off key.
I have a orig. Hondata P28 and a friend provided the chip, Used also another chip, resembles problem.
Ignition functions however!!
What could be???????
Hope you can understand which I mean.
Thanks Nico
If the interface box is flashing then you have a probelm with either the ecu socketing or the eeprom has the wrong program on it.
The LED should stay solid when everything is correct.
