B20V N/A MAP
Posted: Mon Oct 12, 2026 10:28 pm
by KanoB20v
Hey guy here is a b20v map i've been working on myself street tuning its been a work in progress but i would love any kind of feed back just to help me grow as a self taught tuner i've still got some thing to work out (like getting a really stable AFR and idle hunt when at temp) {kind hard to stabilize running 1050cc IDX injectors and yes ik way more head then i probably need} test at your own risk tho
also note i am doing a little bit of retuning due new clutch and 10lb flywheel (less inertia) [retarding timing]
also using a FWRL tuning knock sensor(stand alone 52mm pod knock sensor with a headphone jack to listen to the motor in real time)
emphasis on the feed back and help if anyone is willing to help or fine tune with me
MOD LIST
11.5.1. high compression pistons stock rods rs bore(84mm i think)
skunk2 pro series intake manifold
tri y headers(4-2-1) 2.5in exhaust
1050 idx injectors
aem fuel rail
Blox H.S.L. cams
supertech valve springs
-1degree on exhaust cam gear
70mm throttle body
92 pump gas
