SI K20A3 Vs. RSX K20A3
caorndorff
Post by caorndorff »
Why is the Si reflash have a rev limit at 7700RPM and the base RSX at 7300RPM when they are the same motor?
The K20A3 RSX does not make the same top end power as the K20A3 Civic Si engine due to the intake manifold differences.
caorndorff
Hondata wrote:The K20A3 RSX does not make the same top end power as the K20A3 Civic Si engine due to the intake manifold differences.
So if we have a type-s or si intake manifold on would you recommend to go with a si reflash on a base then?
Use the Civic Si reflash for the PRB intake manifold.
caorndorff
Hondata wrote:Use the Civic Si reflash for the PRB intake manifold.
What is the PRB manifold?
PapiTuyo
Post by PapiTuyo »
Type S/Civic Si manifold ;)
teh leet ep
PM ME FOR BEST PRICE ON K24A2 SWAP :)
Status: K24Z3 Hybrid rebuild in progress.
