JRSC, Hondata, and lumpy idle
CIVIC dude
Post by CIVIC dude »
Hello there,
i have a 00 civic si with hondata s200b with rc 440 injectors, ihe.
After the hondata install i have been having this lumpy idle situation where the idle jumps from 1000rpm - 2000rpms.
Its really starting to upset me!
I have had the TPS set at 0.45v. I have also gone back to the tuner and have had the IAC duty cycle adjusted. It seemed to have fixed the problem.
this was last october. Since october the car has been in storage till now. never driven. I have just recently put the car on the road again and the problem has seemed to return.
Can anyone here help me? My tuner requires an appointment months in advance. Could my IAC valve be bad?
I could take a small video clip of the tach showing the lumpy idle surging if it helps at all?
Sounds more like a vacuum leak.
CIVIC dude
Every vacum hose and line has either been replaced or checked for leaks.
thanks
anybody else??
Quick test: unplug the idle valve. If the idle doesn't drop to 450-600 rpm, you have a vacuum leak.
CIVIC dude
I'll try that and report back!
CIVIC dude
apparently im not the only one having this problem:
check out this link: http://forums.clubsi.com/showflat.php?C ... ost5304550
CIVIC dude
i noticed the sticky topic above about thermostats, which got me thinking..... I have a spoon rad cap. I took it off and have noticed for the last 2 days now, that my lumpy idle doesnt happen as often at all. Im actually crossing my fingers to say that it may have stopped for now lol.
Does this sound crazy or is it a possibility??
CIVIC dude
Hondata wrote:Quick test: unplug the idle valve. If the idle doesn't drop to 450-600 rpm, you have a vacuum leak.
I unplugged the IACV valve and the idle instantly dropped and idled normal.
does that mean i have a vacuum leak??
thanks
