Problem with Kpro
PapiTuyo
Problem with Kpro
Post by PapiTuyo »
Hello,
I am a first time user of Kpro. I own a 2003 Civic Si. I have a PND Ecu (base rsx) that has been upgraded to Kpro. I installed the Kmanager software, and also the USB drivers. Im running the latest version.
Im using the Base RSX ecu because of some drama i experienced with my ep3 ecu
http://hondata.net/forum/viewtopic.php?t=3128
I tried installing the kproed ecu today, and came into some problems.
1. My idle is EXTREMELY rough.
2. My car's tachometer doesnt respond to RPM changes
3. The engine sounded like it was goign to die.
4. I was able to read that the primary 02 sensor circuit had a malfunction*
This is VERY VERY odd, since my car was RUNNING w/no primary 02 sensor problems......
I turned it off, as i didnt want to risk any damage to my engine...
I rechecked my calibration, and all was correct. I had uploaded the Civic Si high octane tune. I only run 93 octane, as i had been running the reflash (on an ep3 ecu) previous to getting kpro on the base rsx ecu.
I can only imagine that the base rsx ecu is somehow incompatible with my ep3 harness....I specifically asked if it would work before upgrading....I mean, i know the ecus are different, but the only difference would be that some pins are unused...
I have attached the datalog for 15 seconds of one of my attempts...I dont knwo what is goign on :(
This is extremely dissapointing to me, as this is finals week here and I need to leave home next week as my semester is done...:(
teh leet ep
PM ME FOR BEST PRICE ON K24A2 SWAP :)
Status: K24Z3 Hybrid rebuild in progress.
Ok, I've already replied to your post on another forum, but here it is again in case you miss it:
The base / type-s & civic si ECUs are all compatable, apart from specific circuity like the reverse lockout and the secondary intake runners, so the base ECU should work on a Si.
All the ECUs are tested before they leave Hondata so chances are it is sometime to do with the calibration not being uploaded correctly. Try these steps.
1. Make sure you have the latest KManager installed (1.2.0.1)
2. From the KManager help menu select 'Update USB drivers'.
3. Restart laptop.
4. With the ignition on use the 'Clear security' function.
5. Switch off ignition, close & restart KManager just to be sure.
6. Try uploading a base calibration first, check the immobilizer is disabled and see how the car runs.
7. If that works then try whichever EP3 calibration you want to run.
PapiTuyo
Post by PapiTuyo »
OK....went for round 2 today for Kpro install
different results, but now my problems are bigger :(
So i checked that my version was the latests. Ok good so far. updated my USB drivers, ok cool did that (waited for the bar to go accross then restarted the computer). Did the clear security function.
My car started beeping and flashing lights as soon as i did this. I assumed this was part of the "clear security" function.
I turned off the ignition and closed and restarted Kpro. I uploaded the Civic Si k20a3 factory calibration.
Clutch engaged, turned the key...No response.
Tried again, no response, the motor doesnt even try to turn on.
I try to reupload, but now my Kmanager says that ignition is not on...Im stuck....I cant upload new things...
I dont understand what im doing wrong. Yesterday at least the car turned on. It was ROUGH. tachometer was off, and i wouldnt run on it at all, but now it wont even turn on.
Are the ecu pin outs the same!? I mean, i know ive been told that they are, but im about to go nuts. I didnt expect any trouble installing this....I honestly expected this to go through with out a problem. I can only imagine that somehow the calibrations arent going through. Im honestly afraid that all these "attempts" are causing damage to my car....
Please, if ANYONE has experienced ANYTHING like this, post up and offer some help. I REALLY need the car drivable by the end of next week, as its finals week right now....
teh leet ep
PapiTuyo
URGENT HELP
Post by PapiTuyo »
ok, tried again today
Found out my battery had died...i left tha cabin light on when i took out the ecu and it wasnt charged. ok so i get my friends battery and put it in.
Tried uploading the ep3 calibration. THe k20a3 civic factory calibration.
I got the SAME problems as day one. My tachometer isnt responding to changes. My idle is EXTREMELY ROUGH. I dont understand what could have gone wrong. I havent touched any electrical things since before i sent ou my ecu, and my car was running strong before hand...
IM experiencing the following problems
1. ROUGH idle
2. Tachometer doesnt work
3. What sound like knocks
I uploaded the high octane tune for the k20a3, got the same problems, then the low octane tune, same deal.....
When i rev the car, i get a very very unpleasant engine rev noise. I wish datalogs could datalog sounds, as it almost sounds like if something was in the motor. My car has never acted his way. Ive heard of a couple of people having similar problems, but solving them by using a "non downloaded" calibration. I dont know what to do.
I may be a first time user, but I am not some clueless kid. Im a mechanical engineering student at UF. This is my finals week and this thing is driving me nuts :( . I didnt expect anything like this to happen. I mean, ive followed all the directions the T. I have tried contacting Hondata directly, talked to Matt. Im told that the problem is electrical....this is odd, since my car was working find before hand. I dont know, it just seems so unlikely that my car would have developed and electrical problem while my ecu was out of the car.
I dont know what to do. My home is over 400 miles away. If i cannot get it working correctly by next friday, i am going to have to tow it home :(
PLEASE HELP ME IF YOU CAN.....
Ive attached a datalog of my attempts to get it running....
teh leet ep
taikahn
Post by taikahn »
I would try:
A) A different laptop.
B) Re-installing/Reformatting your laptop and KManager.
C) A different USB cable, and check its connection.
D) How'd you get the battery recharged? you sure you have enough power?
E) Check for viruses on your laptop.
Tai Kahn
From the datalog the injector duration is a little high, but I see that you get an o2 sensor error almost straight away.
To me it looks like something is shorted out and grounding an input of output from the ECU. The only way you will narrow down the problem is to either borrow another ECU (and swap immobilizers if necessary) or start check wiring to see what circuit if faulty.
Since you have had problem with the o2 sensor in the past, and you get an o2 sensor error in the above datalog, I would start there. You could start by unplugging the o2 sensor and see if anything changes. From there start working through the trouble shooting in the manual for the o2 sensor heater, since you are getting that error code.
BTW just post in one forum so all the posts are together.
PapiTuyo
Post by PapiTuyo »
So today i think i have finally found the problem :(
Today i tried my friends laptop in my car. I was advised to do this by some people. Tried it, got the same results as the first day, ROUGH IDLE, no tach..
So we decide to try putting my kpro unit on his car. I was reccommended to do this by Hondata themselves, as they said the ecu wouldnt harm the car and this would help determine what is wrong. I figured this would at least let me know if the problem was solvable with a stock ecu.
Ok, so we plug in the ecu in his car. Upload the si factory calibration. Turn the key....
SAME PROBLEM
-Rough Idle
-No tach movement
-Disturbing engine sounds
-CEL...primary 02 sensor circuit..
I get worried as i dont want to mess up my buds car. So we do one final try and take a datalog.
This is the kicker. I put back his stock ecu, and lo and behold, everything is fine. No tachometer issue, no rough idle, no CEL....
I would put his ecu in my car, but the whole immobilizer issue is an obstacle....I dont have my stock ecu...story
This was weird, since the Hondata techs ive talked to assured me that the tachometer issue was definately due to an electrical problem in my car. My car was working fine before i send the ecu's to hondata, and i havent touched my electrical system. Since the tachometer issue, and primary 02 circuit problem transferred over to my buddies car, and later corrected themselves with a stock ecu, im pretty certain it can be inferred that the problem lies in the hardware...
Im pretty sure that this proves that my electrical system is not at fault. I dont really know what else to do. Im probably going to check the sensors on my car anyway, but like i said before, they worked before the kpro, and my buddy's sensors worked after we finished testing my kpro on his. I unfortunately finished my testing today after the Hondata techs had left. I guess ill have to see what can be done.
This kinda sucks, im assuming im going to have to send it back....I havent gotten to enjoy ONE drive with the Kpro unit. To top it off, i am at school far from home, and my family is goign to have to rent a u haul car unit to take my car home, as i refuse to drive it on the kpro in its current condition and my semester ends soon. :(
bump if anyone has experienced anything like this...
...ive attached both of today's datalogs
first = the datalog on my car
newtons- the datalog of my kpro unit on my buddies car
teh leet ep
PapiTuyo
Post by PapiTuyo »
ecu is being overnighted to you guys. Please test it and see what you can do. My car was running fine previously :(
I have to leave my residence by nest week, and i might end up having to tow my car :(
teh leet ep
misterdude
sucks don't it
Post by misterdude »
Dude I read all the problems your haveing and I can totally relate I haven't been able to drive my integ for weeks cus my hondata ECU blew up for some unknown reason, its not a problem with the car cus my stock ECU runs it with no CEL but it just runs too damn rich without the proper mapping I had in the hondata. Im in the process of locating a new computer since they only have a 30 day warranty on the hondata ones.
Hope you get better results then I did.
PapiTuyo
Post by PapiTuyo »
EVERYTHING IS FIXED!!!!!!!!
Thanks for all your help guys! When it came down to it, you guys took care of a customer very well. :) I dont have to tow my car home :)
teh leet ep
