Problem with Hondalogger V3-6-3
Clutch
Post by Clutch »
Just installed the NEW logger and I can't get it to connect.
I have had NO problems with the previous versions...everything connects just fine. I also installed the NEW ROMeditor V3-6-3 and it connects and logs fine.
I tried getting ECU information within the logger and it can't connect. I try this in the previous logger version and connects no problem.
Anyone else having this problem?
What do I need to do to get the NEW version on logger to work?
FYI
s200 w/ datalogging and boost
Have you updated the ROM image to the new version using Romeditor (file convert rom, then saving after converting)?
Clutch
Post by Clutch »
Spunkster wrote:Have you updated the ROM image to the new version using Romeditor (file convert rom, then saving after converting)?
Yeah...I bet thats what I did wrong. I opened up my BIN in the new ROMeditor and just hit the save button. I'll try the convert option.
Can't believe I missed that. :oops:
