newbe question
roger1
newbe question
Post by roger1 »
Just had hondata s200 installed and the immobilizer/key function is gone. I see some questions in the K-pro area about the immobilizer, none in the s200 area.
Does the immobilizer/key work with the s200?
Am I being dumb < I should have known that it was going away!!!?
If it does work with s200 how do I get it back?
From the car theft capital of the country any suggestions appreciated.
The more you do to your car; the more someone else wants it.
You loose the immobilizer and it cannot be used unless you go back to your stock ecu. There is no way arround this since an OBD1 ecu is used.
