VTEC CUT OFF. HELP>>
99turbogsr
Post by 99turbogsr »
I have S200 with dataloggin options.. VTEC cuts off in 6200 RPM in every gear.. WHY??
when I just plug it in in the first it was working fine. but after few mins when I tried to hit VTEC again it start cuts off in 6200RPM in every gear...
Do you have the 3 step option? If so, what clutch switch are you using? Have you tried unplugging the clutch switch from the interface box?
99turbogsr
no, I do have the 3-step options, I using the facotry clutch switch... do you suppopse put the hondata clutch switch in for launch control, right? you can't use the facotry one..
I'm gonna unblugging the clutch switch from the interface box see if it works
