need help.... p28 witch hondata s200
changt
Post by changt »
i have just finish installed my p28 with the hondata s200 in my civic 98. i have to convertion to obd1, i took off the check valve. car does start but it have very low or bad ideal ( around 400 rpm ) then it dies. i tried cliping off j12 but it still doing to same thing. please help any one..
thanks
What check valve are you referring to?
changt
Post by changt »
i am talking about the linkses check valve that go's on top of the throtle boddy,
changt
Post by changt »
how do you attach picture? so i could show you how the check valve looks like
Is the check engine light on? Is the interface box flashing or solid? If you can datalog are there any error codes?
More info is needed.
changt
Post by changt »
hmmm.. there is no check engine light, can't datalog, was not enable when bought it, though i believe i bought it with that mod enable. have to go back and ask the guy that i bought it from. the box sometime is flashing and sometime it stays on.
thanks
