Question on my ECU??
ak94gsr
Post by ak94gsr »
k, i have a p28 chipped ecu. its already socketed and with looking over all the installation instructions from hondata it looks like everything has been done for me cept cutting j12 and soldering the 4 pin connector in for datalogging
has anyone else had this happen before??
oh and since my s200 kit came with 2 chips. am i supposed to install one of these or can i just leave my skunk2 chip in since all i want to do at this point is datalogg??
emotionisdead
Post by emotionisdead »
you need to run the hondata chip that is flashed for datalogging. the skunk2 program will not support it. correct me if i am wrong guys. i am no sure about the j12 jumper though, i bought my s200 used and it had everything already installed.
EMOmob
You must follow all the instructions in the installation manual
http://www.hondata.com/downloads/s200%2 ... manual.doc
ak94gsr
Post by ak94gsr »
i did go thru the instructions
and it looks like all i need to do is cut j12 and solder the connection
but i would like a backup response to the skunk2 chip not supporting datalogging?? i thought the 2 chips i got with my kit were blank and need to be burned
You cannot use the Skunk 2 Chip...there is no difference in the smaller chips, they are latches.
ak94gsr
Post by ak94gsr »
K, so i will do what i said above and also install one of the chips supplied
will my car run right or is this just a base program chip
sorry im just still a little cloudy :?
You will need to contact your dealer about a basemap. Handata ships the chips blank and it is up to the dealers to put a basemap on them.
ak94gsr
Post by ak94gsr »
k thanks, i just talked to the company where i got my s200 and they said all i need to do is send one back and they do it for free
