02 input signal wire help?for plxm300
tboostdsi
Post by tboostdsi »
i am trying to hook up my wideband o2 sensor w the plxm300 on a 00 civic si, i need to know what color wire the 02 signal input is. Also, when i hooked the plx device up the first time, the car ran fine for about 10 seconeds then the car dies or the ecu shuts the car off. I think the ecu isnt reading the air fuel. i am using the bosch wideband o2 at the header, and the oem o2 at the cat. (2 o2sensors total)please help. thanks.
All the information you will need can be found at http://www.hondata.com/techplx.html
tboostdsi
wideband 02 dataloging
Post by tboostdsi »
thanks, what if i want to datalog wideband . I plan on buying romeditor and romulator so i can tune my car myself and make my on chips/?
EGHATCH
Post by EGHATCH »
u need pocket programmer too
you wont learn until you actually do it.
