no cel...not even when just turning the ignition on
skunksol
Post by skunksol »
I've got a p28 that's been chipped with a socket by someone before I got it. I never really noticed it before but the other day I saw that my cel wasn't comming on when I jumped the wires to set the timing or even when I'm just turning the ignition on....Any thoughts on why this is? I did plug in a P06 i had sittin around and it does come on then so i know it's somewhere in the computer. Thank you!
MECP First Class Installer
1994 Del Sol B16 86mm bore
2005 Subaru Legacy GT
burned out bulb?
skunksol
Post by skunksol »
thought about that and put the po6 in just to make sure and it turned on so it's def something with the p28
K I L R O Y
Post by K I L R O Y »
Not sure but I have heard that some of the chips around override error codes basically to be forgiving for some of the jackleg swaps running around. Could be that it disables the cel altogether. Just a guess though
EGHATCH
Post by EGHATCH »
check your r77 in the ecu, it might be burned
you wont learn until you actually do it.
