Eliminate Sensors with K-PRO
K20EG
Post by K20EG »
I would like to run my K20A2 with as little sensors as possible. Does anyone know which sensors are absolutely need to run the K20A2? Will K-PRO be able to eliminated all un-needed sensors? Are there any difference in performance when sensors are disabled? Would I be able to use the RSX base maps to run my car for a while before I get it tuned?
What sensors are you wanting to remove?
K20EG
Post by K20EG »
Any sensors that the K20A2 doesn't need to run or can be disabled. I don't care about the emissions control stuff. I want the K-PRO to run at optimal performance and not have to be restricted by the sensors.
Running with all sensors is recommended.
K20EG
Post by K20EG »
Well...I've heard that if you disable the O2 sensor through K-PRO the car will run alot stronger. Is that true?
No that is not true. The key to making maximum power is in proper tuning.
K20EG
Post by K20EG »
What about the EVAP system? So you still have it hooked up on your swap?
OBD2 functions can be disabled in the K-Pro software. I would recommend downloading the software so you can take a look at exactly how it all works.
http://hondata.net/updates/index.php?ap ... n=download
K20EG
Post by K20EG »
Thanks I have the software...just curious if I disable OBD2 functions will give out better performance.
The only sensors you can remove is the o2 sensors and the EVAP/PCS. There is no different in power. Unless it is a custom wired race vehicle then removing the sensors is likely to cause more trouble than it is worth.
