Rsx-S Primary 02 sensor voltage
hardcorersxs
Post by hardcorersxs »
Doug/Derek
Do you know the output voltage for the primary o2 sensor? The reason i ask is that i found this information.
Mikey
The primary o2 is current based and not voltage based. THe PLX will not work for the K-Pro.
If you wire anything other than the stock o2 sensor into the ECU, you will burn out the o2 controller in the ECU.
sprinto7
Post by sprinto7 »
Hondata wrote:If you wire anything other than the stock o2 sensor into the ECU, you will burn out the o2 controller in the ECU.
Is it possible the repair the ECU after the O2 controller has been fried?
Del Long
No it is not. You will have to buy another ecu.
sprinto7
Post by sprinto7 »
Spunkster wrote:No it is not. You will have to buy another ecu.
What would it cost to have the KPro tranferred to a different ECU.
This one works fine, except for the A/F reading.
Del Long
The policy will be that you send your damaged ecu withthe K-Pro to us along with a working ecu and for $100 we will transfer the K-Pro to the new ecu and we will then keep and destroy the damaged ecu as we do not want them being resold and causing us and others problems in the future.
sprinto7
Post by sprinto7 »
Spunkster wrote:The policy will be that you send your damaged ecu withthe K-Pro to us along with a working ecu and for $100 we will transfer the K-Pro to the new ecu and we will then keep and destroy the damaged ecu as we do not want them being resold and causing us and others problems in the future.
No problem, I'll start searching for replacement ECU. Then when the Autocross season is over I'll send them both in.
Thanks.
Del Long
