K-PRO and UK CTR
Rolfb
K-PRO and UK CTR
Post by Rolfb »
I do have an UK spec CTR with a PRA ECU. I am considering a K-PRO, but before placing an order I need some more information. Which options do I have. If I would like to go for a new ECU it seems to be K-PRO with a new PRB ECU according to the Hondata website. Will I be able to use this ECU in my UK spec CTR, or is my only option to send my ECU to a Hondata retailer for installation of the K-PRO?
My preference is to buy a new ECU.
Regards Rolf B
Rolfb
Post by Rolfb »
I would really like to have feedback from Hondata on this issue. Is K-Pro available for the PRA ECU? According to the "K-Pro" web page it seems to be available, but according the "Applications By ECU" page, only Reflash is available. Can you please clarify which options that is available for the UK CTR. As an alternative, will I be able to use a PRB ECU with K-Pro?
An answer would be appreciated.
Regards RB
CivicVTi
Post by CivicVTi »
K-Pro is available for the PRA. If you want a new ECU, you have to get a PRA cause the PRB works with a wideband o2 sensor and is not compatible with the Euro CTR.
