Help! need conversion table zeitronix wb with hondata
CTR88
Post by CTR88 »
all wires are soldered according to installation manual. datalogs perfectly with the zeitronix software. but i would like to use the romeditor software to datalog. i used the ar/volt readings that came with the wb but doesn't come close. my readings on hondata don't even move. reads like 10.xx when its really 14.7 on the zeitronix lcd.
please help. i have the output wire soldered onto to d14. its in open loop and o2 heater disabled. anyone else use it with hondata?
What is the voltage range of the wideband output?
CTR88
Post by CTR88 »
according to there data sheet. its starts from 0.15v:9.7a/r to 3.27v : 21.2a/r
the readings are off by alot.
turbosi92
Post by turbosi92 »
CTR88 wrote:according to there data sheet. its starts from 0.15v:9.7a/r to 3.27v : 21.2a/r
You need to create a custom table in the settings menu. If it still doesn't work, it is because this wideband doesn't not output a linear signal....aka AEM UEGO.
CTR88
Post by CTR88 »
is it possible we'll see an update that will work with zeitronix in the future?
from zeitronix data sheet
Volt:|0.15|0.31|0.46|0.62|0.78|0.93|1.09|1.24|1.40|1.56|1.71|1.87|
AFR:|9.70|9.90|10.1|10.3|10.5|10.7|11.0|11.4|11.7|12.1|12.4|12.8|
Volt:|2.02|2.18|2.34|2.50|2.65|2.80|2.96|3.00|3.12|3.27|
AFR:|13.2|13.7|14.2|14.7|15.6|16.9|18.5|18.8|19.9|21.2|
kesnut
Post by kesnut »
http://www.hondata.net/forum/viewtopic.php?t=3176
this will hep u build ur own table
