Nitrous questions........
nicklk
Post by nicklk »
ALRIGHTY, I am a new owner of a s200 kit and am looking at getting nitrous before going up to get fully tuned......
Looking at a NX Wet kit with a 75hp shot...
I have read, and read, and read about nitrous kits with Hondata and everyone says that a dry kit is best with Hondata due to Hondata increasing fuel through the system. But that would mean you would need to increase your injector size wouldnt it??
I am running 11:1 compression so I am already increasing the injector duty cycle, so I would think that I would need larger injectors....where is if I ran a wet kit, the need for bigger injectors wouldnt be needed.
ALSO, rahter then a WOT switch at the TB, could I run a user controlled switch, that can work in relation with the nitrous control in the hondata.......
CivicVTi
Post by CivicVTi »
You can use a wet kit and have the fuel enrichment set at 0 inside Hondata. You can also decrease your timing and control nitrous activation through Hondata.
