calibration for k24a2 EP3
fermata77
Post by fermata77 »
hi there,
I recently finished k24a2 swap. I have ep3 ecu based K-pro.
I don't see any k24a2 calibration for ep3 ecu based k-pro.
don't know what to do.
And..i have big problems.
The gauges gone crazy.
Every gauage, like speedo, pointing 100km/h while i'm driving
40~50. and goes up and down. some times it stays 0km/h
temp, trip odometer also not working. Gas gauge too.
After i finish the swap , i used k20a2 base map and worked fine.
after a week or so, the idle went up to 3000rpm all of a sudden,
and the gauge problem came out.
HELP!!!
Just load one of the PRB calibrations for the k24a2.
As for the gauges, if the problem dos not go away with a different calibration, you may have a wiring issue or some faulty sensors.
