another noob (kpro for 05 ep3)
bee619
Post by bee619 »
I reall wanna get a Kpro for my 05 ep3 and run this for a while till I have enough for k20a2 swap.
my question is...
1)"To use the K-Pro on a 2005 RSX, an adapter harness is required, a 02-04 specially modified ecu must be modified for used and the primary oxygen sensor from an 03-04 must be used. " is this the same case for the 05 Civic Si?
2)When I decide to drop a k20a2 into my 05 Honda Civic Si, could I use my existing kpro but with the k20a2 map or would I have to send my kro back in or buy a new kpro for k20a2?
much thanks...
The adapter aplies only to the RSX.
YOu can use your existing ECU, but if you have a 6 speed tranmision, you will not have reverse lockout with the SI ecu.
