K-Pro Question on Tuneability
guamrsx
Post by guamrsx »
I just sent my ECU to get the K-pro and I was wondering how will my car run with just using the flash for the cybernations turbo 10 psi 12ohm injectors? If I wasn't to change anything and leave it like it is, will I have any problems? I live in Guam and there are no dynos here. The military is going to ship me back to the states Nov 2006 and then I can go get on a dyno. But until then I still want to be able to race a few times and just play around. I will be putting the K-Pro into my 2003 RSX-S. Any suggestions will be helpful. Thanks
No one can tell you how well it will run until you actually try it. Since all cars are different and if you add to that that the more changes you make the more variances you will have, this is just not a question that has a specific anser.
IF you have exactly what the engine had that this was tuned for, then it may run fairly well, but this is just a guess. SInce this is a fully tunable system you will just have to start with that calibratiuon and begin making changes to safely and reliably run your car.
