Limp Mode Need Help!!!
gen2teg13
Post by gen2teg13 »
Ok first off I have a 91 integra that was converted over to obd1 with a turbo ls/vtec. Right now my car is in limp mode so I connected my laptop to see what was going on and it's showing 3 codes that i'm throwing 9 CYL Cylinder sensor, 23 KS Knock Sensor, and 41 Oxygen sensor heater. So pretty much my question is how can I get rid of these codes, I'm still searching through several forums trying to find anyone else who is throwing these codes as well, but I figured I would create a post here to see if someone could help me.
Did you change th distributor? If you have, then your wiring is incorrect and you need to double check it.
gen2teg13
Post by gen2teg13 »
I did change the distributor. I have an OBD1 Distributor with a wiring harness that allows me to connect to the OBD0 harness. I purchased the harness from locashracing.com.
I would suggest contacting Locash about how to wire the distributor with that harness adapter then.
gen2teg13
Post by gen2teg13 »
There was really no wirng done, it's a plug and play harness.
http://locashracing.com/store/product_i ... ucts_id=57
This is harness I'm using for the distributor, I'm also using thier ecu adapter harness.
You said you swapped distributors...therefore you had to change some wires around. Contact Locash for help with this, as they have the most experience with OBD0-OBD1 conversions.
gen2teg13
Post by gen2teg13 »
I e-mailed locash to see what they say, hopefully they can help me out with this.
