base map help please
eRACING
Post by eRACING »
My brother has a stock internally JDM B16, S200B, RC 440 Injectors, running a Rev Hard T3/T04E turbo at 7.25 psi. Until he welds up a wideband bung I cannot tune for A/F and fuel.
My question is, until he puts in a bung, what base pre programmed map should I run.. Currently I burnt him the "b16afmaxturbo9lbs-440-60-4500-B16A Fmax Turbo 9 lbs" map off the custom tables provided in Rom Editor... This map obviously has him running extremely rich in fuel causing the car to bog quite a bit.
Maybe this is for the Hondata people direct, but is there a better map I could use for his @ 8psi setup on 440 injectors??? Please let me know.. Thanks
eRACING
Post by eRACING »
anyone?
I would recommend just using a stock basemap adjusted for injector size and custom boost tables created under EDIT, CREATE BOOST TABLES.
eRACING
Post by eRACING »
can anyone tell me how much boost the "b16 440inj Greddy Turbo" map is based on located in the custom tables??
I do not recommend using the custom tunes, as they are old and very out of date. You could just start form a new map and create your own boost maps. This will require less adjusting and fixing when you begin tuning.
