problem with hondata??
b20luda
Post by b20luda »
this only happens sometimes..im using a fully optioned S200 with a PR4 ECU. when ever i rev the car out near redline only sometimes it will just act like it shutoff.. the ck engine light comes on/flashes and it wont do anything..i can let off and the engine is still running but i try to get back into it again and it acts like its hittin the revlimiter..at first i thought it was boost cut but i diasbled that and it still does it..anyone have an idea of whats going on..also if u cylce the ignition switch or let it rev down to an idle it will go away and u can drive normally again??
It sounds like loose wiring that is agrevated by vibrations at high RPM. Check all your wiring and make sure th interface cable is not crimped or damaged.
b20luda
Post by b20luda »
that interface cable is new, got any other ideas
sparky
Post by sparky »
i'm having a similar problem, when i datalog the LED illuminates, but i can't pull an error code. i haven't tried reving it up when it throws the CEL but it has been happening more frequently.
It could be a loose wire anywhere in the h arness fo the vehicle.
b20luda
Post by b20luda »
well it dosent do it with the stock ECU..never had that prob until i switched to hondata...so im sure thats ok..its happens very intermintantly..it does sound like a loose wire..maybe its something with the conversion harness..damn the wires...damn them
thudreem
Post by thudreem »
I'm having the same problem. I have a turbo car and under lots of boost it will cut right out, almost like I shut off the car. It will throw a CEL but when you go into hondalogger and Check Error Codes it has NOTHING. I have a brand new cable from the interface box to the ECU.
I though t it was the boost cut and I disabled that. I have no clue what it is?
cinq
Post by cinq »
thudreem wrote:I'm having the same problem. I have a turbo car and under lots of boost it will cut right out, almost like I shut off the car. It will throw a CEL but when you go into hondalogger and Check Error Codes it has NOTHING. I have a brand new cable from the interface box to the ECU.
I too is having the same problem. Boostcut is disabled, but it still kicking in now and then. I wonder what the problem could be. Any more help would be appreciated. Thanks.
RMS
Post by RMS »
sean, have you caught this with a datalog? '88-91 civics with obdI conversion i've seen similar to this a couple times. ended up being a wire in the main harness associated with the firewall mounted map sensor.
no stored code though?
RaVer Motorsports (559) 733-4711
ravermotorsports@earthlink.net
Could also be an aftermarket ignition system, or aftermarket spark plug wires.
Turbo Vtec Ef
Post by Turbo Vtec Ef »
I have had this same problem many times also:
89 civic obd-1 conversion s200b in p28
What could it be with so many with the same problem?
Squad S-rd
Pre 92 vehicle are not supported as there are many wiring differences and things which we can not anticipate. THis does not sound like a problem with the Hondata software or code, but some random wiring issue on the car. I personally have an OBD1 converted 87 Teg that has no problmes what so ever. Wiring is everything...one incorrect ground could be the whole problem.
cinq
Re: problem with hondata??
Post by cinq »
Anyone find the solution for this problem yet? Bump for more updates.
