Different AFR with A/C
EGHATCH
Post by EGHATCH »
okay. car is running idle at 14.7-15 with no a/c. if i turn the a/c on, it will go to like 17s or 18s! so i added more at idle so its now idling at 14.7 with A/C. if i turn of a/c it will go down to 12s! :( i know this is not normal, could there be a bad sensor?
you wont learn until you actually do it.
DaX
Post by DaX »
Are you using shielded wire for your o2 signal? Could be interference...
EGHATCH
Post by EGHATCH »
im running open loop..
CivicVTi
Post by CivicVTi »
When you turn your AC on, due to increased load, the idle RPM rises (about 850 from 750 I think) and the car needs less vacuum to idle. SO you basically move right and down on the map from the initial idle (with no AC). Your maps might not be perfectly calibrated at this new area and that's why you are running lean.
