CEL after reflash on 05 EP3?
HONDA GHANDI
Post by HONDA GHANDI »
I have yet to pull the codes but thought I would check here first in case this is supposed to be normal. I installed a Reflashed ECU into a 2005 Si today and now the CEL is on solid. It wasnt on before I sent the ECU in. Normal to have it on now? Immobi is disabled, will that cause it?
Unplug and re-plug the connectors, making sure they go in all the way.
HONDA GHANDI
I tried that already. I will give it another shot this morning and see what I can find. I will also pull the codes too, Saturday afternoon I jumped the SCS and the light did not flash anything so Im not sure what is going on with it.
erikssi05
Post by erikssi05 »
Hondata wrote:Unplug and re-plug the connectors, making sure they go in all the way.
that didnt wotk and i have a p1456 code... what to do???
WHen did you get the reflash, and what is the serial number of yoru ecu?
erikssi05
Post by erikssi05 »
Spunkster wrote:WHen did you get the reflash, and what is the serial number of yoru ecu?
a few months back(jan- feb) but it never turned off and ive taken it to the honda dealer and they said that there is no evap anywhere ... serial number is 37820-PNF-A13 thanxs in advance...
erikssi05
Post by erikssi05 »
WELL I TOOK IT TO HONDA AGAIN AND THEY SAID THAT IT WAS A "HARD CODE" STORED IN THE ECU AND THAT I NEEDED TO REPLACE MY ECU THEY DID NOT FIND ANY EVAP LEAKS AND SAID THAT IT WOULD BE LIKE 1200 FOR A NEW ECU... HELP PLEASE... ERIK :(
