Auto tune making completely different fuel map. Normal?
blownintegra
Post by blownintegra »
I noticed that through my use of Auto tuning my base map is beginning to look more flat/linear rather than the two hump configuration that the stock map had.
It appears to be accurate on my wideband 1-2% off in columns through street tuning.
Is this normal to see such a variance from stock?
I have an LS with JRSC @ 9psi and RC440 injectors.
Also, how do I go about tuning the areas with super low vacuum or super low revs @ the top row and far left columns? I cannot get my car to stay in those areas long enough.
This sounds normal for a JRSC. The vacuum columns will look muhc like the high vacuum columns of an NA tune.
blownintegra
I meant super high vacuum, not super low vacuum.
The column all the way to the left and all the way to the top.
I cannot keep my car a 26 in. of vacuum and tune those areas.
Any tips?
boosted_si
Post by boosted_si »
26in/hg is a decel value...
13.1@110...12's on the way
1999 EBP Si...Built and boosted
blownintegra
I know. :wink:
It is extremely difficult to decel without having the injectors turn off.
What is the recommended way to tune this area, or is it really necessary?
Or should I just plug #'s in there and be done with it?
thanks.
