Kseries ecu factory knock retard
Razathorn
Post by Razathorn »
Does the factory ecu retard ignition on knock... I have heard yes and no. I'm curious. I realize that kpro does not, but I am un clear on if the ecu did originally.
No. The stock ECU has a 'programmed retard' where it shows a knock retard which is not as a result of the knock sensor.
Razathorn
Post by Razathorn »
Hondata wrote:No. The stock ECU has a 'programmed retard' where it shows a knock retard which is not as a result of the knock sensor.
Do we know where this retard value comes from?
