Open or Closed Loop
K20EG
Open or Closed Loop
Post by K20EG »
For NA K20A2...which mode is safer to run as a daily driven car (open or closed loop)?
closed loop is best.
K20EG
Post by K20EG »
Will the primary O2 sensor be utilized at all under closed loop, because my O2 sensor is messed up. The AF is reading 28:1 under open loop and 38:1 under closed loop. If I run closed loop it wouldn't matter what the AF is reading right?
tryfe
Post by tryfe »
K20EG wrote:Will the primary O2 sensor be utilized at all under closed loop, because my O2 sensor is messed up. The AF is reading 28:1 under open loop and 38:1 under closed loop. If I run closed loop it wouldn't matter what the AF is reading right?
Closed Loop's whole principle is utilizing the primary o2 sensor in achieving a constant 14.7 a/f ratio.
