NEED HELP!!!!problems after innstall of s200b on p28 us obd1
freezer
Post by freezer »
if i use the romulator and load in a hondata rom (h304) i gett the check light and i can not communicate with the hondata interface. if i burn a chip with rom (h304) i allso have the same problem and the red led flashing slowly on the hondata interface. the car runs normal to 4000rpm and shut of
if i burn a stock rom (304) or creating a new rom (stock rom) the ecu is in limp mode, but i can communicate
with the hondata interface and the romulator so i can use the hondalogger/romulator to recording
Do not load the roms this way. Try just going to file and click new. Then select a v3 rom and then select a P28 ecu then use either standard tables or standard tables from a different ecu. Do not use the custom tables. Finish creating hte rom and burn it to a chip and make sure the interface box is solid.
freezer
Post by freezer »
Tanks for help Spunkster:)
i have try that now...
the interface box is solid but i gett the check light!!!!
and ecu is in limp mode rev 3200rpm
i gett 2 error codes when i use the hondalogger (see pic)
Silverbeast
Post by Silverbeast »
Disable those sensors in your ROM and then re-burn the .bin file.
freezer
Post by freezer »
Tanks!!! no more check light!!!!
but now i have a new problem... :?
i replace the 240cc with 550cc
i set the new size and fuel presure to 47psi
thats works not god on idel speed!!!!
bouncing from 500-1000rev
look at the movie
http://www.putfile.com/media.php?n=idle-not-normal
