k-pro o2 sensor error
vtec9
Post by vtec9 »
my car is euro civic type-r
k-pro gives engine error code 41 and engine check light is on
does anybody have an idea about this
thanks...
41 Primary oxygen sensor heater
What program are you loading in tot he ecu? Make sure you are loading a PRA calibration or you will have problems.
vtec9
Post by vtec9 »
I tried a lot of map the cel is still on
I disable p0135 o2 heater the cel is off but after 5 minutes it's on again??
02SilverSiHB
Post by 02SilverSiHB »
vtec9 wrote:I tried a lot of map the cel is still on
make sure you aren't using the .6 version... I got that cell with that version
07 Si Sedan
Are you using a PRA calibration?
vtec9
Post by vtec9 »
I download the latest version of k manager
and I went to service and we check the o2 sensor cable and put another o2 sensor the cel is still on it gives error code 41
how can I check the pra calibration?
You aren't answering the question. Please tell us exaclty how you are creating the calibration (every option you choose).
vtec9
Post by vtec9 »
I tried a lot of calibration it gives an error every calibration
I upload civic type-r factory and the cel is still on
For the last time. Please tell us the ECU type you are using...is it PRA, or PRB...etc? Are you loading a PRA calibration or a PRB calibration?
randall
Post by randall »
have the same problem, prb k-pro ecu on a euro type R. wired in the extra wires according your schematic, heater warning gone now, still no O2 signal. have installed a primary rsx-s O2....with the O2 relay wired in according your schematic, all triple checked and wired correctly...but no O2 signal somehow. downloaded the rsx-s with jdm cams cai exhaust basemap......
would like to know the answer.
thx
02SilverSiHB
randall wrote:have the same problem, prb k-pro ecu on a euro type R. wired in the extra wires according your schematic, heater warning gone now, still no O2 signal. have installed a primary rsx-s O2....with the O2 relay wired in according your schematic, all triple checked and wired correctly...but no O2 signal somehow. downloaded the rsx-s with jdm cams cai exhaust basemap......
thx
I noticed that I'm getting a P0166 and P0134 error now. If I read the manual...its says the P0166 is a code due to a short somewhere...and not the sensor...great...oh and it says the either that or it's the ecu. It's been like this since I started using the 8 version. But I'm betting it's still something with the sensor...I just need to start trouble shooting it this weekend
07 Si Sedan
Look at the diagram attached...I cannot promise anything from this diagram, but was told it is correct.
randall
Post by randall »
funny, cause this is exactly how I wired it in..but still have the problem...
DC5RK20A
Post by DC5RK20A »
I too since using K-Pro, always have used version 8, because just recently have gotten my car back, every now and then will get the error of no O2 detection, I clear the DTC and the CEL goes away. It happens not so often, but it is annoying when it does.
And before Spunkster starts raving out, I am using a PRC ECU. I have just checked and disabled the O2 sensor response, but haven't uploaded it yet to see if it makes any difference.
To me it sounds like something with version 8 K-Manager causing this. Maybe it is something small within the program that Doug and Derek will correct on version 9 or maybe I have no idea what I am talking about. :lol:
The Power of Dreams...
2007 Snisen
DC5RK20A wrote:I too since using K-Pro, always have used version 8, because just recently have gotten my car back, every now and then will get the error of no O2 detection, I clear the DTC and the CEL goes away. It happens not so often, but it is annoying when it does.
No raving....but the PRC is able to control a Wideband and the PRA is not. Is this ecu (PRC) being used in a Euro CTR?
