s300 doesn't like
airshifter
s300 doesn't like
Post by airshifter »
realtime updates while being connected to the ecu(datalogging)
some helpful info for others
makes the car do strange things, once I turned that off realtime seems to be working well
ALSO I couldn't get it to work at all in a vtec converted PO6 but it works fine in a P28. Going to resocket the PO6 and try it with chip and see what happens
That is going to be fun(Removing male pins)
LOTS OF FUN TO COME with S300 :D
Do you have J12 cut on both ecu's? I have seen no probelms with real time update while datalogging. If you are changing a value, try tabing out of that field and the new value will be initialized in the ecu.
airshifter
j12 is cut on both ecu's
something I did notice is the green light flashes between red and green while datalogging and is solid green when not
Silverbeast
Post by Silverbeast »
I have had no problems doing both at the same time either.
airshifter
my problem is fixed now
guess i had a bad one
sent it back with ecu and got ecu back with a new s300
