question, can you use the s300 to control turbo boost?
candymanjl
Post by candymanjl »
I saw on the s300 product page and it says "Two general purpose outputs for nitrous control, dual boost control or similar"
what do you need to set that up, and how is that tuned in the software? Thanks!
http://www.ClubHONDA.com
New car - 2005 S2000 soon to be Turbo'd by Mase
Old car - 1988 CRX Si, B18C, JRSC kit, LHT Intercooler, 25 shot nitrous. 240whp off spray, 265whp on spray.
There are two outputs which can use used to switch almost anything depending on a set of parameters. For instance, you can switch on water injection at a certain engine load and rpm, or nitrous or a dual boost controller (for instance the Turbo XS dual stage boost controller). See the s300 help file for more information.
