Help :D
marc_vtec
Help :D
Post by marc_vtec »
Hi,
First off i live in the uk and own a 1990 Honda CRX VTEC (B16a1)
I did toy with the idea of doing a crvtec conversion, but have decided with proper research, a turbo conversion would see a more relaible motor and more power.
The mechanical side of things dont pose a problem for me, bolting the turbo on should be fairly easy.
I would like to use hondata s200, i know that i would have to convert my car from obd0 to obd1, to do this. I think i need a heated 4 wire 02 sensor, an obd1 distributor and a obd1 ecu.. if i have missed anything could someone tell me?
But I have no clue on the engine management side of things, i dont expect anyone to spoon feed me but if someone could point me in the direction of a post that details all typical noob questions, id be very appreciative. ie. i would have no idea how to tune the s200 i presume i dont just buy the s200, the boost option and plug and play lol although that would be nice. How do i go about doing that?
Thanks in advance to anyone who helps
and apologies if this is in the wrong section :oops:
Cheers
Marc :D
The s300 would probably be a much better solution.
More info on tuning can be found at http://www.hondata.com/stech.html.
marc_vtec
Post by marc_vtec »
What advantages does the s300 have over the s200?
sorry if im being a pain
MacL
Post by MacL »
If you want to tune your car by yourself the s300 is definitive cheaper, cause you don't need the software, emulator and burner to buy! :wink:
And the s300 is more comfortable I think! :roll: :wink:
BB1-NA-powered! Be aware of bad english! :-P
marc_vtec
Post by marc_vtec »
Ah, seems the s300 is a better buy.
Marc :D
