Extended RPM
95c1v1cs1
Extended RPM
Post by 95c1v1cs1 »
Can't seem to find where I can get the extended rpms onto the map.
Can anyone point me in the correct direction.
Thanks,
Corey
Right click on the RPM indexing. You should also go to Help, Contents and click on table window. Changing index table values.
95c1v1cs1
Post by 95c1v1cs1 »
Thanks, I changed the numbers but was not able to have extended rows. Is that the correct way to do it?
Thanks,
Corey
