clutch switch... did I mess up and hurt something?
twkdcd595
Post by twkdcd595 »
I hooked up the clutch switch real quick the other day and everything was all good.
worked great and no problems... well today I go to change some of the rev points and before I even get that far, it does not even work anymore at all.
hmm so thinking loose connection and disconnect the switch temp... which the led is now off on the interface box but the car runs fine.
plug it back in and I get a red light but when I push in the switch the light will slowly go on and off kinda irradically style.
anyways I taped to the top oe clutch switch and this is a s200b with options.
any suggestions or thoughts? loose connections or did I fry the interface box?
thanks for taking a second to read this.
Plese explain exactly in details how you had teh switch wired up. The interface box should not flash, expecially if all you have plugged into it is the interface cable.
twkdcd595
Post by twkdcd595 »
top oe clutch switch taped to the supplied clutch switch cable.
