No realtime Sensor views
smracing
Post by smracing »
It worked when I first installed the ECU, then I screwed up my laptop. I did a clean re-install and reboot. I can load to the ECU and make changes but have no sensor view. What did I do wrong?
Otherwise the product is great.
Just running a stock P28 calibration. Nothing special yet.
What do you mean you have no sensor view? What happens when you try clicking the datalog button?
smracing
Post by smracing »
Nothing. When I first installed the ECU it worked fine. I could see all sensor readings, rpm, etc After I reformatted my laptop. not the ECU. I get no datalog/ sensor readings.
Are you able to upload a calibration?
smracing
Post by smracing »
Yes I can upload tunes. I solved the problem. Check all my connections and re-installed my USB drivers and it is working great now.
