S300 base map problems
D@nny
Post by D@nny »
Im having a problem getting a decent base map.
My setup is 1000cc RC injectors and a gm 3 bar map on a 2.0 fully built gsr motor with a gt35R
The s300 base program will not start or idle unless I add 100 percent to the overall fuel trim. then it will idle VERY lean and the map jumps all over the place from rich to lean with steady fuel pressure....
Does anyone have a 1000cc Base that works?
Silverbeast
Post by Silverbeast »
What you should try is taking off all the correction to begin with. The air temp and the water temp set all to 0.
I would then take the map section for idle and add fuel to it slowly. try to set the timing in these areas at about 20 degrees. Also, make sure that the correct map sensor was selected.
D@nny
Post by D@nny »
Even with the correction down or at 0 it still gives it no fuel.....the temp correction adding fuel isnt hurting it as its running very lean....
converting the s200 rom to s300 does not work corretly either and it completely screws up the fuel...
are you using the first or last 20 columns?
