Ignition flickering when slightly press gas
DarkAngelDC5
Post by DarkAngelDC5 »
The car struggle for a sec when i press the gas, anyone knows why? Could that be ground, spark plug or ignition coil problem?
powerwise modification of the car:
IPS K2
Stock mod airbox
DCRH
HKS exhaust
pulley
IMG gasket
EDIT: added calibration
Last edited by DarkAngelDC5 on Thu Sep 22, 2005 10:57 am, edited 3 times in total.
without the calibration the datalog is mostly useless
racing-honda
Post by racing-honda »
Looks similar to my "problem". See thread
http://www.hondata.net/forum/viewtopic.php?t=3791
No answers sofar.
BTW Checking datalogs from others (for instance on the ClubRSX board) I have also seen ignition doing this...
I was also thinking if it could be caused by grounding, but moving the engine ground from the stock location on the intake manifold to the stud attached to the cylinder head as recommended did not make any difference.
What version of software are you using....from Help about....do not say "the most recent version"
racing-honda
I am currently using the beta version 1.2.0.9.
Before that I was using 1.2.0.7 - showing the same thing.
DarkAngelDC5
Yes using 1.2.0.9. Got that problem as well even with old versions.
Test again with V1.2.0.9 Zero out the ignition compensation (by gear) and set all the TPS retard values to -100 Also, is there a reason for running open loop?
DarkAngelDC5
I tried saving the TPS retard value but it doesn't able to save. Any idea?
I am doing open loop during datalog for tuning the partial throttle
thesilverbullet
Post by thesilverbullet »
got the same issue - is v9b out yet?
'23 RDX SH-AWD
'07 S2K w/ JVT header, Berk 3" header back w/ TP Exhaust, AEM V3 CAI & Flashpro
'02 RSX-S w/cai/exhaust/dcrh/kpro - SOLD
DarkAngelDC5
It will still work by putting the value and upload it.
racing-honda
But does TPS retard affect the ignition flickering?
(my CTR with PRA does not have TPS retard...)
