pre OBD VTEC
crxmatt
pre OBD VTEC
Post by crxmatt »
Why are PR3 and PWO Ecu's no longer supported by hondata?
Staged systems which could be used on the PWo and PR3 have been discontinued. I highly recommend converting to OBD1, then you can use the far superior s300 system.
chri5topher
help
Post by chri5topher »
I have a pr3 b16a swap into a 1992 civic, how do I convert from obd0 to obd1. also where can I get the.
chri5topher
conversion that is
Distributor King offers OBD1 distributors with OBD0 plugs. THen you need a 4 wire O2 sensor and an adapter harness. Our dealers should be able to get all this for you.
